Edge for Android Passkey Issue Feedback
Chumor 0 信誉分
2025-10-19T05:19:06.4133333+00:00
When attempting to use Passkeys for website sign-in in Microsoft Edge for Android, the system fails to properly display the Passkey selection interface com.microsoft.emmx/com.google.android.gms.auth.api.signin.internal.SignInHubActivity. It is worth noting that other browsers on the same device, such as Chrome, can successfully invoke the Passkey feature, indicating the issue is specific to the Edge for Android application.
Key Notes:
The problem lies in how Edge calls the Google Passkey API (other browsers calling the same API function normally). Please investigate integration issues between Edge and Google Play Services.
Reproduction Steps
  1. Open the Microsoft Edge for Android app
  2. Visit a website supporting passkey login (e.g., [https://login.microsoft.com](https://login.microsoft.com"Linkify Plus Plus"), [https://passkeys-demo.appspot.com/home](https://passkeys-demo.appspot.com/home"Linkify Plus Plus"))
  3. Tap the "Sign in with passkey" option
  4. The device passkey selection screen should appear, but instead displays a blank page or error message
Microsoft Edge | 个人资料、同步和登录 | Android
2 个答案
  1. paulr0511 36,990 信誉分 独立顾问
    2025-10-19T06:32:35.3033333+00:00
    您好,谢谢您的提问。很抱歉得知此事。请问您可以确认一下,这款应用是否已经在 Beta 版和 Dev 版中测试过,您可以从 Play 商店单独下载并安装吗?
  2. paulr0511 36,990 信誉分 独立顾问
    2025-10-19T14:56:37.9366667+00:00
    这是用于个人用途还是办公环境?如果是个人用途,最好检查并下载之前运行的旧版 Edge,也可以通过浏览器向 Edge 团队发送反馈,希望他们能在未来的更新中修复这个问题。您可以尝试以下链接,也可以在互联网上搜索在哪里可以下载旧版 Android 版 Edge。
    https://microsoft-edge.cn.uptodown.com/android/versions
    注意:这是一个非微软网站。该页面似乎提供准确、安全的信息。请留意网站上可能宣传经常被归类为 PUP(潜在有害产品)产品的广告。在决定下载和安装任何网站上宣传的产品之前,请仔细研究。
