help me with my audio / mic conflicts
Varun Uday 0 Reputation points
2025-10-25T02:35:33.3333333+00:00
My computer decides to play videos slow and then has no audio , and then sometimes my mic doesn't work, and then sometimes my video just spins around and nothing works. Sometimes it plays static. This happens occasionally, and then if I restart it fixes the issue.
Please tell me a solution for this.
Windows for home | Other | Devices and drivers
  1. Ferdinand Nanalig 24,875 Reputation points Independent Advisor
    2025-10-25T15:18:29.1066667+00:00
    Hi, I am an independent advisor and welcome to Microsoft Q&A.
    Let me help you with this issue.
    Please hover your mouse over the sound icon at the lower right-hand corner, then right-click it and click Troubleshoot Sound. Let the troubleshooter finish its task, then this should either resolve the problem or display an error message.
    If that doesn't work, we need to remove the Audio driver from the Device Manager and restart the PC to reinstall it.
    Here are the steps to completely remove a Device from your computer.
    Step 1. Use shortcut keys Windows key + X.
    Step 2. Select Device Manager.
    Step 3. Expand the entry Sound, Video, and Game Controllers. Right-click the problematic device, which is either Realtek Audio, or AMD High-definition Audio, or High-Definition Audio, depending on the audio device installed in your PC, and select Uninstall device.
    Step 4. You need to check the option Delete the driver software for this device and then click the Uninstall button.
    Step 5. Reboot the computer.
    After the reboot, please see if the problem is fixed.
    If that still does not work, please visit the support website of your laptop or desktop and then download and install the latest Audio driver then restart the PC.
