my power point is not working good
Rohit Godara 0 Reputation points
2025-10-07T11:45:55.52+00:00
my power point is not working good . Place repair it.
Microsoft 365 and Office | PowerPoint | Other | Windows
  1. Alex-L 250 Reputation points Microsoft External Staff Moderator
    2025-10-08T02:50:29.8666667+00:00
    Hi Rohit Godara,
    Welcome to the Microsoft Q&A Forum!
    I understand how frustrating it can be when your productivity app is not functioning properly, in this case PowerPoint. We can work this out together, kindly follow the basic troubleshooting steps and also help us narrow down the issue for you.
    Please give these steps a try to fix common issues:
    1. Update PowerPoint:
      1. Open PowerPoint
      2. Go to File > Account.
      3. Under Product Information, click Update Options > Update Now.
      4. Wait for the update to download and install. Restart PowerPoint when finished.
    2. Start in Safe Mode or disable Add-ins:
      • Hold Ctrl while launching PowerPoint. This helps identify if add-ins are causing problems.
      • Go to File > Options > Add-ins and turn off non-essential add-ins.
    3. Repair Office: Go to Control Panel > Programs > Programs and Features, select Microsoft Office, click Change, then choose Repair.
    4. Check System Resources: Make sure your computer has enough memory, low resources can cause crashes or slow performance.
    Hope this helps! Let us know if there's any updates or if you need further assistance.
