Error installing replication appliance using powershell
Ketan Kute 0 Reputation points
2025-10-06T12:32:09.3966667+00:00
I have downloaded installer from below link and extracted in c:\azuremigratefiles (azuremigratefiles is new folder created in c drive).
https://aka.ms/V2ARcmApplianceCreationPowershellZip
After trying executing DRInstaller.ps1 I am getting a below error.
Extracting DRA installer.
Script execution failed with error This command cannot be run due to the error: The system cannot find the file specified..Exception.Message
Error Record: This command cannot be run due to the error: The system cannot find the file specified..Exception.ErrorRecord
Exception caught: This command cannot be run due to the error: The system cannot find the file specified..Exception
Azure Migrate
Azure Migrate
A central hub of Azure cloud migration services and tools to discover, assess, and migrate workloads to the cloud.
  1. Naveena Patlolla 6,780 Reputation points Microsoft External Staff Moderator
    2025-10-06T12:48:07.34+00:00
    Hi Ketan Kute
    We believe the path you entered may be incorrect. If you’re trying to run a script or access files from C:\dr\DRAppliance,, you’ll need to change the directory to that location first.
     cd C:\dr\DRAppliance
     Then, try running the PowerShell script .\DRInstaller.ps1
    Please let me know if you face any challenge here, I can help you to resolve this issue further
    Provide your valuable Comments.
    Please do not forget to "Accept the answer” and “upvote it” wherever the information provided helps you, this can be beneficial to other community members.it would be greatly appreciated and helpful to others.
