Problem with connecting to a remote PC using the Windows App for iPhone or iPad
Nadav Loutati 0 Reputation points
2025-09-30T12:11:42.78+00:00
Hi
we are trying to connect to a terminal server on iPhone and iPads but no connection is established, the process is stuck on securing gateway and no notification is coming from the authenticator app.
on most devices, it did work on an older version (11.1.9) but on the new version it is not working (11.2)
iPhone and iPad version is iOS/ iPadOS 26 with the 11.2
thank you
Nadav Loutati
Windows for business | Windows Client for IT Pros | Devices and deployment | Other
  1. HarryPhan-2691 7,850 Reputation points Independent Advisor
    2025-09-30T12:47:02.0166667+00:00
    Hi Nadav,
    The fact that it gets stuck on "securing gateway" and doesn't even trigger the Authenticator app is a big clue. This usually points to a handshake issue between the new Remote Desktop client (v11.2) and your gateway server.
    A very common fix for this specific problem is to clear the app's cache. Could you try this on one of the iPhads?
    Go to your device's Settings > General > iPhone Storage (or iPad Storage). Find the "Microsoft Remote Desktop" app in the list and tap on it. Then, select "Offload App" and confirm. After that, just tap "Reinstall App" to get it back. This clears the data without losing your saved PCs.
    This often resolves these kind of update-related glitches. If that doesn't do the trick, the next step would be to check if your gateway server needs any specific TLS security settings updated.
    Let me know if the offload trick works! If this answer helped, please mark it as "Accepted" 🙂
