How to repair your system files using DISM and SFC
Isaac Hernandez 0 Reputation points
2025-09-03T14:57:05.2866667+00:00
How to repair your system files using DISM and SFC?
Windows for business | Windows Client for IT Pros | Devices and deployment | System management components
  1. Domic Vo 7,830 Reputation points Independent Advisor
    2025-09-03T15:48:25+00:00
    Dear Isaac Hernandez,
    Thank you for your inquiry. If you're experiencing system instability, missing features, or unexpected errors on your Windows device, using the built-in Deployment Image Servicing and Management (DISM) and System File Checker (SFC) tools can help restore system integrity without requiring a full reinstall.
    Below is a step-by-step guide to help you repair your system files:
    Step 1: Repair Windows Image Using DISM
    DISM checks and restores the health of the Windows image that SFC relies on.
    1. Open Command Prompt as Administrator Press Windows + S, type cmd, right-click Command Prompt, and select Run as administrator
    Run the following command:
    cmd
       DISM.exe /Online /Cleanup-Image /RestoreHealth
    cmd
       DISM.exe /Online /Cleanup-Image /RestoreHealth /Source:C:\RepairSource\Windows /LimitAccess
    Step 2: Scan and Repair System Files Using SFC
    Once the image is healthy, use SFC to scan and repair protected system files.
    In the same elevated Command Prompt, run:
    cmd
       sfc /scannow
    1. Wait for the scan to complete. You may receive one of the following messages: No integrity violations found – System is healthy Corrupt files repaired – Issue resolved Corrupt files found but not repaired – Run DISM again or perform the scan in Safe Mode
    Optional: Review Scan Results
    To view detailed results:
    cmd
    findstr /c:"[SR]" %windir%\Logs\CBS\CBS.log > "%userprofile%\Desktop\sfc_results.txt"
    These tools are part of the Windows Client system management components and are fully supported in enterprise environments.
    I hope this helps. Just kindly tick Accept Answer that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    Best regards,
    Domic Vo
