How to fix sound system high definition audio device (not plugged in problem)?
Saiqa Khan 0 Reputation points
2025-08-26T06:17:04.2566667+00:00
I got a new Windows 7 installed, and now I’m having a sound problem. The speakers aren’t connecting, and even the PC’s own sound isn’t working. It keeps showing a “plugged in” problem. I’ve tried all the methods, but nothing worked.
Windows for home | Previous Windows versions | Devices and drivers
  1. Mc Shane Anarea 0 Reputation points
    2025-08-27T03:21:42.8533333+00:00
    Try uninstalling and installing the drivers or installing a new driver that works on your version of OS.
