Problem having offline installation of VS 2022 community
Mehtout 25 Reputation points
2024-08-05T08:31:25.18+00:00
Hi all,
I've downloaded a copy with the packages that I need, to install it in an offline machine.
After finishing the download from Microsoft site this is the result :
1212
The problem is that there is only folders and no installer file to install the package.
How I will install this package in an offline machine not connected to the net???
Developer technologies | Visual Studio | Setup
{count} vote
  1. Anna Xiu-MSFT 31,121 Reputation points Microsoft External Staff
    2024-08-06T02:32:12.72+00:00
    Hi @Mehtout
    Welcome to Microsoft Q&A!
    Please refer to the following document to create an offline installation for Visual Studio.
    Create an offline installation - Visual Studio (Windows) | Microsoft Learn
    You need to first create a local layout on the PC with internet connection, then, copy the layout folder into the pc without internet connection to install it.
    You can find the .exe file and downloaded packages in the layout folder.
    Sincerely,
    Anna
    If the answer is the right solution, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".  Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
