Jquery is not working! Class Jumotron does not work
Aakash 20 Reputation points
2024-01-26T23:19:43.8966667+00:00
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="Admin_Login.aspx.cs" Inherits="TMS_Project.admin.Admin_Login" %>
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title>Admin Login</title>
    <link href="../assets/vendor/bootstrap/css/bootstrap.min.css" rel="stylesheet" />
    <link href="../dist/sweetalert2.min.css" rel="stylesheet" />
    <script src="../dist/sweetalert2.min.js"></script>
</head>
<body style="background-color:whitesmoke">
    <form id="form1" runat="server">
        <div class="container">
            <div class="row">
                <div class="col-md-4 mx-auto" style="box-shadow: -2px 2px 29px 1px rgba(0,0,0,0.75); -webkit-box-shadow: -2px 2px 29px 1px rgba(0,0,0,0.75); -moz-box-shadow: -2px 2px 29px 1px rgba(0,0,0,0.75);">
                    <div class="jumbotron text-center text-white bg-primary">
                        <h2>Admin Login</h2>
                    </div>
                    <asp:TextBox ID="UsernameTxt" placeholder="Enter Username" CssClass="form-control" runat="server"></asp:TextBox>
                    <asp:RequiredFieldValidator ID="RequiredFieldValidator1" ControlToValidate="UsernameTxt" ForeColor="Red" SetFocusOnError="true" Display="Dynamic" runat="server" ErrorMessage="Username is required"></asp:RequiredFieldValidator>
                    <br />
                    <asp:TextBox ID="PasswordTxt" TextMode="Password" placeholder="Enter Password" CssClass="form-control" runat="server"></asp:TextBox>
                    <asp:RequiredFieldValidator ID="RequiredFieldValidator2" ControlToValidate="PasswordTxt" ForeColor="Red" SetFocusOnError="true" Display="Dynamic" runat="server" ErrorMessage="Password is required"></asp:RequiredFieldValidator>
                    <br />
                    <asp:Button ID="LoginBtn" OnClick="LoginBtn_Click" runat="server" Text="Login" CssClass="btn btn-primary btn-block" />
                    <br />
                </div>
            </div>
        </div>
    </form>
    <script src="../assets/vendor/jquery/jquery.min.js"></script>
    <script src="../assets/vendor/bootstrap/js/bootstrap.min.js"></script>
</body>
</html>
Developer technologies | ASP.NET | Other
  1. Lan Huang-MSFT 30,206 Reputation points Microsoft External Staff
    2024-01-29T05:23:40.54+00:00
    Hi @Aakash,
    To use Bootstrap Jumbotron, you just need to use the Bootstrap.css file.
    It's not clear from your code which version of Bootstrap you are using, probably because it is older.
    You can try the following code:
      <link rel="stylesheet" href="https://cdn.jsdelivr.net/npm/bootstrap@4.6.2/dist/css/bootstrap.min.css"/>
     </head>
                <div class="row">
                        </div>
                        <br />
                        <br />
                        <asp:Button ID="LoginBtn"  runat="server" Text="Login" CssClass="btn btn-primary btn-block" />
                        <br />
                    </div>
                </div>
            </div>
        </form>
    </body>
    </html>
    Best regards,
    Lan Huang
    If the answer is the right solution, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
1 additional answer
  1. Bruce (SqlWork.com) 81,356 Reputation points Volunteer Moderator
    2024-01-27T18:15:10.09+00:00
    The Jumbotron is ccs only and does not use any JavaScript or jquery.
