Hi Sheneoy,
Hope so you are doing good !!!
Azure IoT Device service is designed for communication between a single device and the Azure cloud. It allows seamless device registration, monitoring, and efficient management. To ensure the highest level of security during communication, Azure IoT Device employs X509 certificates, providing a robust and secure method for device authentication to the Azure cloud.
In contrast, Azure IoT Edge extends Azure IoT Hub's capabilities to edge devices. It is best suited for scenarios where local data processing on the device is essential, minimizing both bandwidth usage and latency. Azure IoT Edge facilitates the creation of custom modules tailored to the specific requirements of your projects. These modules can encompass custom code, Azure services, or third-party solutions. They operate alongside IoT Edge runtime, enabling on-device data processing before transmitting it to Azure IoT Hub. The authentication mechanisms for these modules are adaptable, catering to the unique needs of your IoT applications.
I also mentioning the link below to know better about Azure IoT services like Azure IoT Device and Azure IoT Edge , so kindly check it as well .
https://free.blessedness.top/en-us/training/browse/?products=azure-iot&terms=azure%20iot%20device
I trust this refined explanation clarifies the disparities between Azure IoT Device and Azure IoT Edge concerning device authentication. If you have any further inquiries or require additional assistance, please don't hesitate to ask!
If my answer solved your query , kindly do "accept answer".
Thank you ....
