Problem with SSL Certificate and 443 Port
Luis Miguel Perez Lopez 30 Reputation points
2023-08-04T18:10:40.5733333+00:00
I have a WCF Service in an Azure Virtual Machine, but it doesn't work, and I guess is because SSL certificate, beceause before I was working without ssl certificate ( type http service) and it was working properly.... I tried to use an ssl certificate that is in IIS by default but none of them works....
Do I need to buy an ssl certificate in order to work my WCF service under SSL encription (type https) ???
Windows for business | Windows Server | User experience | Other
Developer technologies | .NET | Other
Developer technologies | ASP.NET | Other
  1. QiYou-MSFT 4,336 Reputation points Microsoft External Staff
    2023-08-09T08:31:43.2033333+00:00
    Hi @Luis Miguel Perez Lopez
    I have two methods for you to use here:
    1.Open Internet Information Services (IIS) Manager
    URL1
    URL2
    URL3
    2.Modify the web.config file directly
    <system.webServer>
    		<rewrite>
    			<rules>
    				<rule name="test" stopProcessing="true">
    					<match url="(.*)"/>
    					<action type="Redirect" url="https://www.lasletrasdelrock.com:8880/View/Index.aspx"/>
    					<conditions>
    					</conditions>
    				</rule>
    			</rules>
    		</rewrite>
    	</system.webServer>
    url4
    Tips: Since I did not focus on the study of regular expressions in order to show the method. Here my regular expression (.*) means that all URLs entered comply with this rule, and you need to check the relevant documentation of the regular expression for further settings.
    Best regards,
    Qi You
    If the answer is the right solution, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
  2. AgaveJoe 1,510 Reputation points
    2023-08-11T13:19:07.99+00:00
    The configuration I suggested and the configuration QiYou-MSFT recommended work perfectly.
    Unfortunately, you are not providing enough information for the community to figure out what's wrong with your configuration.
    I can't work with 80 and 443 ports.
    Is there any way you can explain why you can't work with port 443? I'm asking because https://www.lasletrasdelrock.com is bound to 443 by default. Is there a binding for port 443? Why is the Web Forms application bound to port 8880? What are the bindings for the WCF application?
    Can you share a screenshot of the site bindings?
  3. Luis Miguel Perez Lopez 30 Reputation points
    2023-08-11T17:32:16.5966667+00:00
    Here you go:
    https://www.lasletrasdelrock.com:8880/View/Index.aspx => it works now
    https://www.lasletrasdelrock.com/ => It doesn't work now (page can't be reached)
    If I put the code in the web.config of my project
    		<rewrite>
    			<rules>
    					<match url="(.*)"/>
    					<conditions>
    					</conditions>
    				</rule>
    			</rules>
    		</rewrite>
    Both url's doesn't work :( ... even trying in the virtual machine where the app is located. I'm using the ports 8880 and 4443 because I couldn't work with the ports 80 and 443, these ports are already used by another applications in my virtual machine is there a problem with the ports 8880 and 4443 ?? now they are working properly....
  4. Luis Miguel Perez Lopez 30 Reputation points
    2023-09-17T21:48:45.37+00:00
    One question, is there a way to solve this problem without using IIS, I mean, just using
    Networking page and Network Security Groups and setting up Inbound Rules in Azure portal ???
  5. Ellite Harry 0 Reputation points
    2025-09-30T11:10:45.56+00:00
    Yes, to run your WCF service over HTTPS on port 443, you’ll need a valid SSL certificate bound to your site in IIS. The default self-signed certs in IIS usually won’t be trusted by clients, which is why the service fails under SSL. You can test with a self-signed cert for development, but for production, you’ll need to purchase and install a trusted SSL certificate from a Certificate Authority so clients can connect securely without errors.
